ShaDowStalk3r
Nov 08, 2019Aspirant
Xr500 v2.3.2.56 lan drop out
After updating to v2.3.2.56 on my XR500, I'm experiencing temporary LAN drop out for my PS4. This happens nearly every hour and PS4 states LAN cable not connected, any ideas? This was a non-issue on the previous firmware.
Has a factory reset and setup from scratch been performed since last update?
ShaDowStalk3r wrote:
After updating to v2.3.2.56 on my XR500, I'm experiencing temporary LAN drop out for my PS4. This happens nearly every hour and PS4 states LAN cable not connected, any ideas? This was a non-issue on the previous firmware.- Netduma-FraserNetDuma PartnerWould definitely recommend doing the above and then setting a static/reserved IP for the PS4 in the router LAN Settings.
- ShaDowStalk3rAspirantYes, I factory reset and I have static ip set for the PS4 already.
