jmc7
Apr 08, 2018Guide
XR500 Wireless ACL - missing
Hi all, As I continue to configure the router, I realized the wireless acl is missing under advanced wireless settings. Was this function removed in the latest firmware version v2.2.1.10?
- Netduma-FraserNetDuma PartnerYes I believe it was, instead you can use the Device Manager to block any devices.
- jmc7Guide
Sad to hear this was removed. One reason for purchasing this router was due to having this ACL setting. Is it possible to obtain a previous firmware that still have this feature?
- Netduma-FraserNetDuma PartnerThere was an issue with it as well which contributed to it's removal. It may come back in future once fixed but I have no way of telling for sure.
There are versions available in the download area but I would not recommend it as you may encounter more issues than being on the latest version.
