cosmo2450
Jun 08, 2020Guide
xr500 x2
I have two xr500 and the network looks like this:
mesh extender (in garage)
INTERNET---(cable)->--xr500mid---(cable)-->--xr500front (in AP mode)
The problem I am having here is my computers are all on the xr500front which is in AP mode. Whenever i go to login to manage my router or network, it only lets me see the one thats in AP mode and I cant really manage any settings.
Would maybe running it like this work:
INTERNET---(cable)-- (IN AP MODE)xr500mid--<--(cable)--<--xr500front
I hope that makes sense, ideally I dont want to change it as ill loose one of my cable sockets in the room
- Netduma-FraserNetDuma PartnerI assume you're using routerlogin.net to do this, if you access via the LAN IP then you should be able to access the interface of the one in router mode.
- That was it. Thank you very much
