MurimGomes
Nov 08, 2019Follower
XR500 Xbox one x hardwired issue
I have the xr500 and I’ve had nothing but issues since I got it. First it wouldn’t connect at all. Did a factory reset of the router and it worked! Since I’ve had it though, my Xbox says my nat typ...
aspauld22
Mar 17, 2020Aspirant
Not sure if you got this figured out, but have you tried rebooting modem after you reset the router?
Netduma-Fraser
Mar 21, 2020NetDuma Partner
I'm not sure why this hasn't been answered, perhaps it was posted in another section and was moved. Are you still experiencing the issue?
