MikeCompetillo's avatar
Feb 01, 2019
XR500 Xbox One X issue
I was previously running off wireless for my Xbox one X, but then ran into lag issues (which I blame the Xbox wifi card for). I finally then ran a cable to my xbox (100ft away), and it seemed to work until I turned the xbox off, then went to turn it back on again (with instant on enabled). I read the article here: https://kb.netgear.com/000060532/How-do-I-fix-disconnection-issues-with-my-Xbox-One-console-when-connected-to-Nighthawk-Pro-Gaming-router    but would rather not have to turn instant on feature off, since it would drive my wife nuts. Is there any beta firmware I could try? Or would a Gigabit switch in between my Xbox and the XR500 solve it? Thanks!
  • FURRYe38's avatar
    The Instant ON feature bug is a MS issue. Not a router FW issue.
    You would need to talk to MS about what your seeing with it enabled. It's recommended to disable it.
    • Ah Figures it was MS... Do you know if the Insider Aplha Xbox releases fixes this issue? I'm hoping to try a switch in between to see if that fixes it.
      • FURRYe38's avatar
        I don't know for sure. My roommates box is on the Preview program. His is disabled however I can check to see. Something i'll try this weekend.
