jeremyg237's avatar
jeremyg237
Luminary
Apr 07, 2018
XR500 XBOX PUBG best settings
Just got the router yesterday. Cant seem to find a good GEO filter for PUBG xbox. I live on the east coast (Virginia). Are there any servers in my area or do I need to put the circle around the whole US.
  • Hi Jeremy - within PUBG you can select the server region and I believe the NA server is located in Ohio. This means you don’t need to use the Geo-Filter in filtering Mode.
    Instead, you can add your PC and the Unreal Engine service to your Geo-Filter and then use Spectating mode to see your ping to the server.
    I also recommend your set Anti-Bufferbloat (QoS) to 70% for both download and upload and to the mode High Priority Traffic Detected. This will ensure no congestion can build on your network when you’re playing games.
    • jeremyg237's avatar
      jeremyg237
      Luminary
      Why would I hook my PC to GEO filter, since I am playing PUBG on xbox?
      • XRaptor29's avatar
        XRaptor29
        Luminary
        On the Geo filter, go to the menu and uncheck the strict mode. See if that works. PUBG might be one of those games like destiny where it needs that unchecked.
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi jeremyg237,
    I have a couple friends that play pubg on Xbox. It does have lag for the game. Environment loads slow / glitches throughout the game. The creators are most likely still working on the game and trying to smooth out the details. I play on PC and it is a lot better but still has little things that needs to be smoothen out also. :]
    - Jason N
  • When I am playing this game in the midway the game stops automatically and showing server connection lost.  Dubai data recovery suggests that there is an error in your router that's why this problem is created. This problem is really irritating me.
    • Netduma_Jack's avatar
      Netduma_Jack
      NetDuma Partner
      Hi Sam,
      It's unlikely to be a DumaOS setting  causing this - so let's start with some basic hardware tests.
      1. When the drop happens, is the rest of your Internet still online?
      2. Are you connected wirelessly or wired?
      3. Are you able to connect directly to your modem and play through that? Do the dropouts occur there?
