JCHAP39
Jan 23, 2020Tutor
xr500
router requires a password reset every time i log in.
What firmware are you on?
What modem are you connected to?
Does it do it on all devices or is it specific to a certain device?
have you tried different browsers?
I've read of other routers having issues with certain special characters, have you tried avoiding special characters or switching which ones you use?
- JCHAP39Tutor
firmware is current version
modem is provider issued, not the problem however i checked, plus system was working well until i reset router to factory, I reset due to haveing issues with Netgear ready nas, have 2 units installed.(104,204) which are connected to a nighthawk switch S8000, which is connected to xr500 via cable. i set nighthawk, 104, and 204 to static connections. did this due to back up program could not locate back up location, dns reassigning. lost all data when i thought i had to reset them as well, lesson learned.
yes i have tried different browsers
so this is where im at now, I have the xr500 working :) apparently it did not like my old password anymore, it was not formatted to its likeing or recommendations. it had worked since i first set it up with no issues. solved by resetting password the way it wanted. which should not of been a issue.
still having issues getting the 104,204, up and running, cannot access them thur the router(xr500). I can access the switch but not the nas systems. see image, this is what i get. on all browsers I can access them thur my lap top directly however.
thanks for responding
Can you access the NAS's if you plug them directly into the router?
