Akoni44's avatar
Akoni44
Xr500
I keep getting disconnected from games randomly and my Nat type is fine until I connect it with Ethernet then I get a notification saying I have a double Nate type and it can't connect to the DHCP server and flashes Amber on that Ethernet port. Can someone give me advice on how to fix me disconnecting all the time
  • Have you disabled the DHCP Server on the router in LAN Settings by any chance? Also give your console a static/reserved LAN IP in LAN Settings if you haven't already done so.
  • Disable this, and also I can't find an option to give my Xbox a static IP or at least I don't see it
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      It's on that same page, access using a PC and you should be able to see how to set the reserved IPs.
      • Akoni44's avatar
        Akoni44
        This right here?
