Colt1018's avatar
Apr 28, 2020
Xr500
xr500 won’t find internet connection after powering on, after completing setup wizard and powercycling
  • Are you able to access the interface? Do you know if you require PPPoE or VLAN in order to gain a connection?
    • Colt1018's avatar
      Colt1018
      Guide
      Yup, I have access to the interface, not sure what is needed to connect? The isp would be where to find out right?
