Davidddr
Sep 30, 2022Aspirant
Xr500
Not sure what to do only lights that pop up are USB2 & Ethernet. no power light or anything else are working. Cannot connect to the app.
Anybody have a solution to fix this? Thanks
- Netduma-FraserNetDuma PartnerIf those lights are appearing then the router will be powered on so maybe a faulty LED there. Can you access the interface using a wired PC?
- DavidddrAspirantYes the router is powered on but from what ive seen others talk about I think it’s “ bricked” . I have a laptop accessible to use
- Netduma-FraserNetDuma PartnerCan you access the interface with the laptop?
