paulebble
Jan 14, 2019Aspirant
XR50AC1900 and a XR500 gaming router0 - PS4 Connection better with ISPs modem/router then XR500
Hi,
Please be patient as I am not too savvy with this technical stuf!!!
I would like to know how to connect my XR500 gaming router to my AC1900 modem/router so they are both under the same name/password etc.. At the moment they are both under different network names and passwords. I would like to use the gaming router as a network extender to increase the network signal around my large house? Not sure if it would be called bridging or a repeater?
Any help will be gratefully received.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
