sovietbarfight
May 26, 2020Follower
XR700 5ghz disconnects everyday at the same time
XR700 5ghz disconnects everyday at the same time. 2.4 Ghz band stays up and the LAN devices stay up. I have changed my channels different than surronding wifi networks. Logs shows nothing and statistics show uptime hasn't been reset. Renew and Release of IP's not happening during that time either. Thanks!
What Firmware version is currently loaded? Try first version of released FW?
Is Smart Connect enabled?What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?- Netduma-FraserNetDuma PartnerDouble check in Advanced WiFi settings as to whether the WiFi has been set to turn off at certain times.
