Misterswede's avatar
Jan 31, 2020
XR700 and Wi-Fi stops at 15-20mbit
I have 300 mbit down and 150 mbit up
when I test via cable all is good, and test directly to fiber router all's is perfect
i set up the XR700 not even 1 year old and it tests Wi-Fi and says 300 down and 130 up so that is also good.
when I test the Wi-Fi after all setting is ready it says 15 and max 20 mbit down and gets crazy 190 up
i removed QoS and one time I got good result then it went back to max 20 mbit down
latest firmvare is on and I am about getting a hammer an hit the XR700 after 100 tests
also about to make factory reset
since I bought it I have had 24 mbit so I feel like it has learned that this is max but now fiber and 300 it got lazy
please help me you experts
  • I found it :-)
    The top left corner in QoS there is what down and up are maxed I thing my xr700 had made settings for previous setting
    I have put hem both on 1000mbit so it rocks
    Design bad from net gear to have so important issue hidden in that small menu
    I was about to kill it
