XSlashDashX
Feb 09, 2019Tutor
XR700 disconnecting so often
Hello. Just recently purchased this router and noticed that my PC that is hooked up to ethernet cable keeps getting disconnected every
5 or so minutes.
Current firmware version I have is XR700 V1.0.1.8
Same goes for Wifi. I can be on for a bit and will cut off.
- Netduma-FraserNetDuma PartnerSo this is across ALL devices? Upgrade to the latest firmware version and see if that resolves your issues.
Isn't the firmware I posted the newest?
- Netduma-FraserNetDuma PartnerAh yes, apologies! In that case I would recommend downgrading to this firmware: https://kb.netgear.com/000060213/XR700-Firmware-Version-1-0-0-20 as some people with issues similar to yours have found it doesn't occur on that firmware.
