Misterswede's avatar
Feb 28, 2020
Xr700 DNS
Well this one i cant figure out
I am getting alot of waiting for response on homepages
300/100 fiber connection
I can test a home page works perfect 1ms in oing and then suddenly it stops time out
Its like hickups in DNS. I tried to change frpn ISP DNS to 1.1.1.1 still the same
If i disconnect the XR700 and uses directly to computer all works perfekt
Wht the Piiiiip
  • QoS won't be effective like that as your true speeds haven't been input, put your correct speeds in please. It may be you were experience local congestion and due to your settings this wasn't being mitigated.
  • Are you overly throttling on QoS or using your PC with the Geo-Filter? Have you made any changes to block sites/services in settings?
    • Misterswede's avatar
      Misterswede
      Guide
      Blocked sites are empty
      In QoS i have set it to 800 up and 800 down
      Then checked antibuffer
      The connection is 300 down and 100 up
      The slider in QoS i have set to 80% on both
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
