robert27841
Aug 28, 2020Star
XR700 DUMA OS 3.0
When will duma os 3.0 be release date
the XR700 Firmware Version 1.0.1.24 - Hot Fix still as some bugs and glitches sometime it doesn't load
having to reboot the xr700 often this is ridiculous. For the cost of this product I should be experiencing this much difficulty.
I even signed up for the duma os 3.0 beta in June 2 and nothing yet .
- Netduma-FraserNetDuma PartnerI responded to you on the Netduma forum but what I said there was:
We don't have a specific release date. It's not available for beta just yet but as soon as it is we'll let people know. If you're having issues I would suggest installing the latest firmware using the TFTP method: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP and then doing a factory reset for the freshest install possible.- Thank you everything works now
