matt57017's avatar
matt57017
Initiate
Jan 16, 2019
XR700 Latest Firmware 1.0.1.8 causing massive issue
The latest firmware update is causing wifi devices to not automatically reconnect, or if they do, they immediately drop. It is so bad, it is causing me to rollback to the previous version which works flawlessly. Is anyone aware of this issue?
  • So wired devices never lose connection at all? Is it all WiFi devices? Do you have smart connect enabled?
    • matt57017's avatar
      matt57017
      Initiate
      All WIFI devices. Some stay connected, others bounce.
      I rolled back to the previous version, and everything went back to normal
      • FURRYe38's avatar
        Ok, seems to be issues in latest FW version. NG is on it. Just be patient for the next roll out.
  • FURRYe38's avatar
    Try downgrading to v20...
    • RBosel's avatar
      RBosel
      How does one downgrade to v20? I just recieved this router today and I am really baffled by this issue. Especially due to the fact that is still ongoing today just as much as 2 months ago. I am relieved to hear that it is just a firmware issue. Just confused on how to downgrade is all.
