Nokum87
Dec 07, 2020Follower
XR700 led issue
Hi all,
I bought a second hand xr700 last week and thought I would seek help here before I go for a refund.
The issue I have is that the left hand side of the led light strip doesn’t seem to work this includes the power / internet / wireless 5 & 2.4ghz & 60ghz / guest WiFi led lights, all the other lights work fine and the router itself works with no issues.
I have tried turning them on and off both with the switch and the duma os, I have factory reset and even gone back to the last firmware.
Not sure what else I can try so any ideas would be much appreciated
Cheers
Cheers
1 Reply
- Netduma-FraserNetDuma PartnerIf it's not disabled via the switch/on the interface then it is most likely just a faulty LED as the router is obviously on so if that is a problem then do pursue the refund.
