ShadowMelt
Nov 11, 2020Apprentice
XR700: not getting isp speeds on wifi
Hello, I'm having issues with wifi speeds on the router. My isp upgraded my modem to an gb modem. After the change I tested it out with the tech. I was getting the speeds wired but wireless im getting 450 max. When I'm supposed to get at least 950mbps. I factory reset the router and it detected my new speeds but still wifi is only getting 450 max. Here what have done so far to fix the problem.
Disabled smart connect
Changed 5ghz channels also used wifi analyzer app to find best one.
Turned QoS off and on
Factory reset
Is there anything I can do?
Factory reset
- Netduma-FraserNetDuma PartnerWhat devices are you testing the wireless on? Are they capable of higher than 450Mbps? Have you got faster than that on the WiFi before?
- ShadowMeltApprenticeI have been looking to see if the devices I been testing on are able to but can't find specs been using Note 20 ultra which on 5g WB I can get 1.2gps. The laptops and other stuff I'm not sure. Xbox and ps4 are only able to download around 100mb
- Netduma-FraserNetDuma PartnerIn Advanced WiFi settings enable MU-MIMO, Beam forming and HT160 and see if that improves speeds on the Note.
