Swade123's avatar
Swade123
xr700 Router packet loss
https://imgur.com/HRyZGV3
getting bad packetloss on my new xr700 router, im hard wired to my pc and have seen packetloss intermittently when testing on pingplotter although this is the first time its shown this bad
https://imgur.com/1qR0bDH
this is happening more frequently though, this never happened on my 10yr old asus router, it feels terrible to fork out for a new premium router only for my performance to get worse
  • When it comes to PingPlotter the default interval of 2.5 seconds should be used instead of 1 as that can show issues which aren't actually there. Also the graph below what you have shown there is most important, if that graph doesn't have any red bars after changing the interval to 2.5 then you have nothing to worry about.
    • Swade123's avatar
      Swade123
      https://imgur.com/EjjSzBp
      im still getting huge latency spikes from my router, how can this be fixed? is this a faulty unit? these are 5000%+ spikes at times, that feels completely unnaceptable to me from a new premium router
      • Swade123's avatar
        Swade123
        i should add - i didnt see a way to edit my post, i know the packetloss here is obviously from the server end and not from the router, this was just an image i had handy that showed the router ping spike, it happens pretty consistently every time i test on pingplotter
