Mikeclev7
Dec 25, 2019Aspirant
XR700 Router stopped broadcasting SSID/no wifi
Yesterday afternoon, my wifi stopped working. What I mean is I could no longer find the SSID, on any device, and cannot connect. When I log into the admin page, on the home page it shows the wireless ...
SonzofGod
May 17, 2020Tutor
Did you ever solve this issue? My year old XR700 suddenly started doing this yesterday.... SSID is not showing or intermittent. The WiFi radio button the front appears to do nothing....as well as the Duma OS enable radio button checkbox. Also, the router WILL NOT let me do a factory reset. The power LED just flashed white while I have the reset button pressed....never goes orange.
ALL GHz bands show disabled in the DUMA OS....
Netduma-Fraser
May 17, 2020NetDuma Partner
I've just responded to your topic so hopefully we can get it resolved: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/Netgear-Nighthawk-XR700-all-wi-fi-bands-intermittently-disabling/m-p/1915284
- SonzofGodMay 17, 2020Tutor
thank you, I'm trying now and will update you in my thread
