numo38's avatar
numo38
Follower
Oct 30, 2018
XR700 sft+
Can I use Cisco SFP-10G-T-S Compatible 10GBASE-T SFP+ Copper RJ-45 30m Transceiver Module on my XR700
  • schumaku's avatar
    schumaku
    The Netgear routers don't require "branded" SFP+ modules, so the no-names on whatever code are commonly workable. At least this was the case on the (very similar) X10/R9000.
    • schumaku's avatar
      schumaku
      Thank you Netduma-Fraser for the Kudo - now what if (the OP sent me a PM) an SFP+ is not recognized, or the user can't figure out how ot use the SFP+ on the XR700? Is there a shell access to check the Kernel output once an SFP+ module is plugged?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        I'm not aware if there is unfortunately. I'd advise contacting Netgears support directly in that case.
