bengalvfan2
Oct 25, 2018Tutor
XR700 Slow speedtest
I got my XR700 gaming router with firmware version 1.0.1.2 today and my speed test is about half as what they should be.
I have QOS turned off and only get about 400 Mbs down over LAN
When I connect directly to the cable modem I get 900 Mbs down over LAN
thats odd, have you tried to Hard Reset the router ?
Also maybe Hard Reset the modem and or check the dBmV levels on your modem; they should be within -7 to +7 dBmV.
- Netduma-FraserNetDuma PartnerIs this over WiFi or directly connected through ethernet? If QoS is off then DumaOS shouldn't be the cause. May need to give the router the MAC address of your previous router.
