dahliamo
Aug 07, 2020Aspirant
XR700 VPN not working
I have The XR700, when i run My Ethernet cable “ hard wired “ from my XR700 to my Xbox one x it does NOT mask my IP address. VPN works Wirelessly but not hardwired. I’ve tried everything and nothing works. Level 1, 2 & 3 engineers can’t figure this out as to why this is happening. I swapped out to my old Linskys WRT- 3200 VPN router and it works “ hard wired and wirelessly “ I really don’t want to return this XR700 as it puts up better speeds than my linskys . Any tips would be greatly appreciated. Thank you.
- Netduma-FraserNetDuma PartnerCheck the Device Manager as it may be that your wired PS4 is appearing as a separate device to the wireless PS4 and so you'll need to add that instead of the wireless version.
- dahliamoAspirantI did That awhile back and it gave me double NAT. So that doesn’t work.
- Netduma-FraserNetDuma PartnerNot sure I follow with that, are you saying doing that you did actually get a connection through the VPN but you had a double NAT?
