Carnaged
Sep 22, 2020Tutor
XRM570 iPhone disconnects from WiFi.
Hi,
I have noticed that sometimes even when my iPhone has good signal strength, between 2/3 bars it will randomly drop the WiFi and go to 4G. I have the 2.4ghz and 5ghz seperat3d and usually keep my phone on the 5ghz. In my bathroom which is tiled, I will have between 2-3 bars and full speed but all of a sudden my phone will say 4g.
Today it was connecting and reconnecting and saying no connection to the internet, once I was back in the hallway it was fine. The EX7700 is in the room right next to the bathroom but the phone only seems to connect to it if you turn off the WiFi and then back on it never actively seems to switch to it.
I have logged into the 2.4ghz WiFi network on my phone as well now so if it drops the 5ghz in the bathroom then the 2.4ghz should be fine.
it just surprises me that even with decent signal strength the phone just drops the 5ghz?
- Netduma-FraserNetDuma Partner5GHz does have less penetration through walls so that can happen, you shouldn't notice it on 2.4GHz. Should also help to use a WiFi analyzer and find the least congested channel to put the 5GHz on.
- CarnagedTutor
Hi and thanks for the reply,
My 5ghz is on 105 DFS and there isn't anyone else on that frequency, should the iPhone change to the EX7700 or would it have to be really low signal to move itself? I have noticed if I am near and the phone screen sleeps when it wakes it will move to the EX7700.Im assuming if I used smart connect it would probably just go to 2.4 rather than switching to the EX7700.
- Netduma-FraserNetDuma PartnerOkay using a DFS channel isn't great and could be the issue. Go to the next best non DFS channel and see if that works. It should switch to the next strongest signal that it can.
