greekman
Feb 20, 2026Follower
2.4 ghz
how might I set my modem to 2.4 ghz so I can connect a wireless 2.4 ghz application? thanks
Feb 22, 2026Guru - Experienced User
If you go to:
https://www.netgear.com/support/
Theres a support site you can type in your model number and it'll bring you to the manual, guides, firmware. Its helpful for these types of situations.
