JGNY123's avatar
JGNY123
Any success of connection after factory reset?
I am having the same problem with orbi750. WI-FI is working fine but app doesn’t find the router. Installed new apps on 3 different iPhones but none is working. Very frustrated.
  • I am having the same problem. Please share if factory reset can fix the problem.
  • FURRYe38's avatar
    Factory reset and setup from scratch using a wired PC and web browser at HTTP 192.168.1.1. Don't use Orbi app.
