RockTheGlobe's avatar
RockTheGlobe
Apprentice
Mar 13, 2023
Any way to bypass Armor signup when logging in?
While I have the Orbi app downloaded to my iPad and iPhone, I've avoided using it for the past several months because every time I open it, I can't get past the splash screen where it asks me to agree to a trial of Netgear Armor before it will let me use the app.  Am I missing something?  Is it possible to get past this screen without signing up for Armor, or do I have to activate it in order to use the app and then figure out how to immediately cancel?
  • plemans's avatar
    No there isn't without activating that I know of.
    Annoys the crap out of me too.
    there should be a check mark to "never ask me again" type thing
    • FURRYe38's avatar
      I wish there was a (X) button.
      I guess activate it then you can disable it under Settings/Security with in the NH app.
