rbpeirce
Oct 12, 2026Aspirant
Are Orbi IOS speedtest labels reversed?
I run a weekly speedtest using four apps. In three the download is ALWAYS higher than the upload speed. The Orbi app on my iPhone always shows an upload speed higher than download but the numbers a...
Oct 12, 2026Guru - Experienced User
I've tested a ton of orbi's and never seen them actually reversed. I pay for 2 gig download and 300mbps upload. They've always been right. They might not hit their peak.
I'd just bet that whatever test server you're using, its always maxing out the directional connection. its the problem with the app because you can't change the server you test from
plemans wrote:its the problem with the app because you can't change the server you test from
rbpeirce: Your home network and the specific clients might also factor in. Your iPhone's transmit level is much lower than the Orbi router and satellites.
Are any of your client tests using ethernet?
