RickQ
May 14, 2025Tutor
Can't Access Orbi RBRE 960 After A Reboot
A couple of days ago I used the Orbi app on my android phone to access my router. Just something I do once in a while to check on a remote system. I noticed that one of my satellites was not connecte...
May 14, 2025Guru - Experienced User
FYI: https://community.netgear.com/kb/en-orbi-knowledge-sharing/orbi-app-timed-out-issue/2456583
- RickQMay 14, 2025Tutor
As I mentioned in my post, I'm using an Android phone. I can't access my router using the app and I can't access the router using the web UI either. I have no access at all, nada, zip.
- FURRYe38May 14, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed?
Turn off and unplug modem.
Turn on computers and rest of network.Try a different PC or laptop ethernet connected to the back of the RBR.
Try different web browsers.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message- RickQMay 14, 2025Tutor
Cable Modem is a Netgear CM2050V
Ethernet cable is CAT6A
Keep in mind that this system has been working very well for several months prior to the reboot I initiated the other day.
Power to the modem and router has been cycled multiple times in the past due to internet outages (Comcast issues). The 'Keep Connect' device does this automatically when it detects that there is a loss of internet access. The modem comes up first, then the router. The process takes over 3 minutes to complete. During that time, there is no power to the modem or router for at least 2 minutes. Satellites are not included in the power cycling, but that has not been an issue in the past as both have always reconnected to the router and WiFi enabled devices have then connected to the satellites.
There is only one PC, the video server, at the remote location. Don't have anything else I can use currently to attempt a connection to the router.
I've tried Chrome, Edge and Firefox browsers.
I'm not using any MAC randomizers.
