Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
Royalh13
Oct 28, 2022Star
FYI - A little testing shows that the app probably isn't even trying to pass the logon information to the router.
I tried using an incorrect password for the admin login and instead of returning a message about an invalid password, I got the same logon timed out error...
- FURRYe38Oct 28, 2022Guru - Experienced User
Please submit a bug report using this:
I've passed this on to NG as well.
- Royalh13Oct 28, 2022Star
Already done...
- lundqNov 01, 2022Aspirant
How am I supposed to use this method to submit a bug report, when I am unable to login to the app?
- FURRYe38Nov 01, 2022Guru - Experienced User
What do you see when you shake your mobile device when you see the "Logon timed out" message?
https://community.netgear.com/t5/Orbi-App/How-to-report-a-bug-on-the-Orbi-App/m-p/2140980#M3630
- alanfgNov 14, 2022Aspirant
You cannot do a bug report using this method if you cannot log into the Orbi app in the first place due to the timeout error. Is there any way to submit a big report via computer?
- MichelH61Nov 14, 2022Star
Just shake your phone whilst being on the logon screen!
- Bayamon62Nov 15, 2022GuideSame issue on a Samsung S21+ app was removed and reinstalled, not working !
I used the wifi manager to access the router and the web interface works...app is pupu !- FURRYe38Nov 15, 2022Guru - Experienced User
Can anyone let me know if this method works for Orbi app as it seems to for the Nighthawk app?
Same process...might help.
- GlennnnnNov 16, 2022AspirantI'm having the same issue. Is there any update on when the new Android app update will come out? I actually bought a new rbs50 today (already had an existing one but needed extra satellite)... That was before I knew of this issue... but now thinking I should return it if Netgear isn't going to continue supporting this product! Very frustrating!
