raymondtkc
Nov 15, 2020Aspirant
CBR40 not communicate with Orbi apps and wired connected computer
Hi, For the past 1 month I got the problem of the Orbi app not communicate to the Orbi CBR40 system. This problem no matter within the WiFi network or outside by "connect with anywhere access". ...
Christian_R
Nov 20, 2020NETGEAR Employee Retired
Hello raymondtkc,
May you try the recommended steps that I mentioned in the thread below.
Thanks,
Christian
raymondtkc
Nov 23, 2020Aspirant
Hi Christian,
I already done all the below before but no luck. The problem is not just the Orbi app cannot access the router, even I use wired connected desktop also cannot access the router. The router completely isolate itself and not allow any connection no matter through the apps or using desktop with wired connected. The only way I can do is reset the router. Hope any big bros can provide me a solution.
Raymond
- DbensetteNov 24, 2020TutorI have been having the same issue with the rbk852 for over a month now as well.
Any time I want to connect to the router through the app or through a browser I have to reboot the router first. It then works, for a day or so...
