jwalls2
Oct 17, 2025Aspirant
connecting Atomi outdoor lights
I have Atomi outdoor can lights that I assume have to run on 3.2 and not on 7 mesh. How do I get them to work with 7 mesh? I don't want to use old Orbi system just to run lights. Thanks for your...
CrimpOn
Oct 18, 2025Guru - Experienced User
If the "Old Orbi" was WiFi5 and the new "mesh" is WiFi6 (or WiFi7), there is that comment in the Troubleshooting Guide about turning off 802.11axx features on the 2.4G channel
Thanks to plemans for mentioning how to replace one WiFi router with another. I have kept the same WiFi credentials (SSID/password) for over 20 years. Everything "just connects". And, if I decide to "go back", simply plug in the old system and everything connects automatically to it.
- StephenBOct 18, 2025Guru - Experienced User
FWIW, I keep mine the same also.
