RoMo1951
Jul 26, 2026Aspirant
Device List Failed To Load
Using the device manager in the Orbi App, I get the message ‘device list failed to load’ Why is that? How to fix? Also under Security it does not show any devices scanned All looks OK when I chec...
HappyCat
Jul 26, 2026Virtuoso
It appears (to me) that you have two options:
- Shake the smartphone and create a Bug Report to send to Netgear support.
https://kb.netgear.com/000064839/How-do-I-submit-a-bug-report-or-logs-from-the-Nighthawk-or-Orbi-app - Provide more information to allow people on the Community Forum (not Netgear employees) to assist. Such as:
o Which model of Orbi WiFi router is this?
o What version of firmware is currently running on the router?
o What version of the Orbi 'app' is running.... on what device? (Apple? Android?) - Is the Orbi app connected locally, or using Anywhere Access?
(does the Orbi app behave differently if you change the connection?)
- RoMo1951Jul 27, 2026Aspirant
Thank you for getting back to me and sorry for being so tardy with the information I posted. Specifically though:
Orbi model RBE771
Firmware Version V10.5.20.10
Iphone 15Pro
App version 2.54.0.37
Thank You
