RoMo1951
Jul 26, 2026Aspirant
Device List Failed To Load
Using the device manager in the Orbi App, I get the message ‘device list failed to load’ Why is that? How to fix? Also under Security it does not show any devices scanned All looks OK when I chec...
Jul 27, 2026Guru - Experienced User
OK, submit a bug report thru the app. Hopefully should be corrected on next app update.
Try uninstalling the app then reinstalling it.
If you need to do anything with the system, can always log into the RBRs web page if needed.
RoMo1951
Jul 27, 2026Aspirant
OK, thanks for the feedback. Much appreciated
