birdsafe
Nov 01, 2025Aspirant
Devices List
The other day I opened the Orbi app and opened the device list and the display was a bit different, it had devices listed by band (2.4hz, 5hz, 6hz) and I think it also had a toggle for each device (t...
- Nov 02, 2025
Yeah, that view you saw was probably part of a recent Orbi app update or a test feature they were trying out. It sometimes shows up briefly and then goes back to the regular list after an update or restart. There isn’t a setting to switch to the band-sorted view yet, but it’ll likely return once Netgear rolls it out fully. Just make sure your app’s up to date for when it does.
CrimpOn
Nov 02, 2025Guru - Experienced User
I do not have a "Test" version of the Orbi app. My version was updated automatically from the Google Play Store (as it always is).
p.s. I have an old cell phone that is no longer in use. It has Orbi app version 2.44.0.4515 on it, and the Filter Icon appears in the corner the same way it does on the current app.
When I click on the Filter Icon, that causes the box to appear giving choices about which devices to display and how to sort them.
