mgcblossom
Apr 18, 2026Tutor
Hardware issue
Recently we returned from a trip, now our ORBI satellite seems to be an issue, the connected camera goes out (off line) although when we sync the unit all comes back as it should. Netgear representa...
mgcblossom
Apr 30, 2026Tutor
The ORBI36 with the issue is connected to a Verizon modem, although the camera goes out, comes back, goes out. The issue, unable to see the ORBI application on the phone, it is attempting to connect with our other ORBI system in DE. Seems ORBI can be a good alternative with extenders are required, the downside is ORBI is not the system when different states are involved. I will continue to work on some options. You would think ORBI would be able to reset the admin password, maybe they will work on that along with outlining the recovery steps required with set up. Any possible solutions to our issue are appreciated.
