ggarrigues
Dec 08, 2025Aspirant
How to connect to the APP a system which is already configured ?
I already have a RBK50 system with 5 satellites. It's working properly. But I changed my mobile phone and I lost the system on the APP of my new S25 ULTRA. I have tried to add it but 3 of 5 satelli...
- Dec 16, 2025
ggarrigues wrote:
I have tried to add it but 3 of 5 satellites are considered as not connected on the Network Mapping section.
The Orbi 'app' was successfully installed on the new phone and the app logged in successfully to the router. The issue is that three satellites do not appear on the network map, correct?
CrimpOn
Dec 16, 2025Guru - Experienced User
ggarrigues wrote:I have tried to add it but 3 of 5 satellites are considered as not connected on the Network Mapping section.
- ggarriguesDec 16, 2025Aspirant
Yes exactly !
Through webapp (orbilogin.net) all satellites appear as connected (4 wired and 1 through 5G)
But through ORBI APP (Android APK), only 2 satellites appear as connected ...
I did an update of ORBI APK to the last version and now all satellites are displayed. Thank you for your help. Much appreciated ! Geoffroy
