rmfrance
Sep 29, 2026Aspirant
I have an RBR50 router with two RBS50 satellites, all running firmware version 2.7.5.6
I've been seeing this same problem ever since I installed iOS 27. I have an RBR50 router with two RBS50 satellites, all running firmware version 2.7.5.6.
I've tried rebooting the router and rem...
Sep 30, 2026Guru - Experienced User
rmfrance wrote:I've been seeing this same problem
What problem???
Someone might have moved your post, but whatever happened we have no idea on what your problem is.
- rmfranceSep 30, 2026Aspirant
Sorry - this was intended to be a reply to:
- StephenBOct 01, 2026Guru - Experienced User
Orbi app 2.54.1 – RBR50v2 “Logon timed out”; same credentials work with app 2.45.2 and web interface | NETGEAR CommunitiesThx. I'm still on 26.7.1 myself (I like to wait for the .1 release of major iOS updates). You might wait for that, and see if the problem resolves.
FWIW, while I do have the orbi app installed, I almost never use it - I much prefer the web admin interface.
- rmfranceOct 01, 2026Aspirant
I just installed iOS 27.0.1, and that didn't resolve the problem. Maybe 27.1 will do the trick...
I mostly use the web interface too. I chimed in mainly to let JYG83 (and others) know that this doesn't seem to be an isolated issue, and in case it's a problem with the NETGEAR app, and not with iOS 27.
