rmfrance
Sep 29, 2026Aspirant
I have an RBR50 router with two RBS50 satellites, all running firmware version 2.7.5.6
I've been seeing this same problem ever since I installed iOS 27. I have an RBR50 router with two RBS50 satellites, all running firmware version 2.7.5.6.
I've tried rebooting the router and rem...
rmfrance
Sep 30, 2026Aspirant
Sorry - this was intended to be a reply to:
Oct 01, 2026Guru - Experienced User
rmfrance wrote:this was intended to be a reply to:
Orbi app 2.54.1 – RBR50v2 “Logon timed out”; same credentials work with app 2.45.2 and web interface | NETGEAR Communities
Thx. I'm still on 26.7.1 myself (I like to wait for the .1 release of major iOS updates). You might wait for that, and see if the problem resolves.
FWIW, while I do have the orbi app installed, I almost never use it - I much prefer the web admin interface.
- rmfranceOct 01, 2026Aspirant
I just installed iOS 27.0.1, and that didn't resolve the problem. Maybe 27.1 will do the trick...
I mostly use the web interface too. I chimed in mainly to let JYG83 (and others) know that this doesn't seem to be an isolated issue, and in case it's a problem with the NETGEAR app, and not with iOS 27.
- FURRYe38Oct 05, 2026Guru - Experienced User
FYI there is newer FW available than what you have, might give this a try:
https://www.netgear.com/support/product/rbk50
