Papasmurph
Nov 04, 2020Aspirant
IOS 14 upgrade is freezing Wifi
Hi
I have had a similar but different issue after upgrading iPhone x and iPad Pro to IOS 14. My Orbi Wifi has been operating without issue for nearly 2 years with up to 20 different devices attaching (other IOS devices, Apple TV's, Smart TV's, Sonos etc). All device upgrades including IOS have completed within this 2 years and no impact on the reliability of the Orbi WiFi. However I upgraded both my iPhone x and iPad Pro same evening about 4 weeks ago and since then whenever I attach either my iPhone or iPad (with IOS 14) to the Orbi WiFi it freezes/stops the WiFi for everything, thats including other IOS (V13) devices smart TV's etc., the only way to restart the WiFi is take IOS14 devices off the wifi and reboot the Orbi router, then so long as I leave iPhone x and iPad Pro off the Orbi wifi then no issue it works away.
As the iPhone x stops the Wifi when it attaches I cannot use the Orbi app but I do have the option to allow access 'Local Network'. So instead I use the https://orbilogin.com and can connect to Orbi router. I have updated the firmware, done a factory reset, installed as new (as few times) and still same issue, IOS 14 devices causes the Wifi to freeze. I have never installed Orbi Nighthawk as an App.
I am totally frustrated and while I did contact Apple and they did escalate they clearly identify the problem as the Orbi router issue.
Anyone had a similar issue and at this stage before I throw the Netgear equipment into the trash I would try anything.
- horsecoreAspirant
I am having a similar issue. Upgraded an iPhone 11 Pro to 14.1 sometime in October, was receiving constant prompts to enter my network's WiFi password. Some quick searches revealed this to be related to VPN services running on the phone - had one installed from Bitdefender Armor (via Netgear), removed, and issue seemed to be resolved. My wife's phone, also an 11 Pro, did not have this issue as she is not using Bitdefender Armor at this time; all other devices in the home were operating normally.
Fast forward to Monday this week and my internet connectivity on my phone is not working - connection to our home wireless network is fine but it behaves as if there is no internet connectivity. Rebooted modem and router, no difference, rebooted phone, no difference, reset network settings on the phone, no difference. I had a pending update to 14.2, updated, no change. Disabling and re-enabling WiFi seems to correct the issue but only momentarily. My wife's phone is also experiencing the same set of issues. All other devices in the home are working as expected.
Found a post on Apple's developer forums (https://developer.apple.com/forums/thread/651079) suggesting to try Google's public DNS addresses - no change. Also on that forum, a user described changing their security type on their router to "WPA2+WPA3" which unfortnately for us is not an option with the Orbi RBR50, we only have WPA2-PSK [AES] or WPA-PSK [TKIP] + WPA2-PSK [AES]. Router and satellite are running the latest firmware as well, V2.5.2.4.
Checked adding a new wireless network on the iPhone Pro 11 and of the security types available, default is WPA2/WPA3...there is no WPA2 only. I cannot validate what was present on my phone before updating to 14.x but I have an old iPhone 5s running 12.4.8 and WPA2 by itself is an option and this phone has no issue with internet connectivity.
My guess would be something to do with the WPA2/WPA3 security type currently set on IOS (could have been present before, not sure) and the lack of the option on the router.
Anyone else have thoughts?
- horsecoreAspirant
As an update for my specific scenario, I did change the security option on my RBR50 to WPA-PSK [TKIP] + WPA2-PSK [AES] and now connectivity to the internet seems stable. My theory may hold some water but curious what others are seeing.
- tweadickAspirant
I am having the same issues as above, I did change the security option on my RBR50 to WPA-PSK [TKIP] + WPA2-PSK [AES] but it has had no effect.
My iphone works fine in other locations on wi fi, my wife's phone which is android has no problems with my orbi, the issues appear to be between my iphone since I updated to ios 14 & my orbi router. Whenever i log into my network it crashes everything & the only solution is to reboot the router. This has been going on for a number of weeks & as I work from home it is a nightmare
