sajnikanth's avatar
sajnikanth
Initiate
May 11, 2025
Issue seems to be with the latest iOS version. Here's how I fixed it
Issue seems to be with the latest iOS version. Here's how I fixed it:
  • You need an older iOS device. I used my kids' iPad running iOS 15.7
  • On the older device, install Orbi app and login to your netgear account
  • Without Anywhere Access, login to your router (admin / <password>)
  • You should have logged in successfully
  • Go to Settings -> Anywhere Access
  • You should see Anywhere Access is enabled
  • If so, Disable and Enable it. If not, just Enable it
  • On your device running latest iOS, quit and relaunch the app
  • When you see the screen to login, quickly click on Login using Anywhere Access
  • You should be able to login now
Good Luck
No RepliesBe the first to reply
