Daniel-UK
May 16, 2019Apprentice
Network map keeps randomly changing on iPhone app
When I look at the Network Map in the iPhone app, I keep getting always different network topology and differen colours for the devices (green, magenta, orange) every time I look at it!
Strangely e...
Daniel-UK
I tried to post it in the Orbi app forum... but there is a bug... i.e. "Labels" are required to be selected (mandatory field) but no labels have been defined so cannot post there!!!
Does anyone have a solution for this crazy problem?
- FURRYe38May 16, 2019Guru - Experienced User
Troubleshooting doesn't work as a lable?
Others are posting there...
- Daniel-UKMay 16, 2019Apprentice
No! There is ZERO labels available to choose if you try to post in the "Orbi app" forum... sorry I don't have time to send you also a screenshot for this bug..
No worries, I see whats happening. Just tried it.
The following labels are not available here: Orbi
Not sure what other users are using. Lets see if we can get some moderator help on this.
