Daniel-UK
May 16, 2019Apprentice
Network map keeps randomly changing on iPhone app
When I look at the Network Map in the iPhone app, I keep getting always different network topology and differen colours for the devices (green, magenta, orange) every time I look at it!
Strangely e...
May 16, 2019Guru - Experienced User
Troubleshooting doesn't work as a lable?
Others are posting there...
Daniel-UK
No! There is ZERO labels available to choose if you try to post in the "Orbi app" forum... sorry I don't have time to send you also a screenshot for this bug..
- FURRYe38May 16, 2019Guru - Experienced User
No worries, I see whats happening. Just tried it.
The following labels are not available here: Orbi
Not sure what other users are using. Lets see if we can get some moderator help on this.
