Daniel-UK
May 16, 2019Apprentice
Network map keeps randomly changing on iPhone app
When I look at the Network Map in the iPhone app, I keep getting always different network topology and differen colours for the devices (green, magenta, orange) every time I look at it!
Strangely e...
DexterJB
May 16, 2019NETGEAR Moderator
Hi Daniel-UK, we will look into the label issue. As for the app, may I know what version you have installed? Also, does the behavior stay the same after a re-install or on another device?
Dexter
Daniel-UK
2.3.5.20 is the version of the iPhone app
Yes, same issue after reinstall and using it from other devices
