Daniel-UK
May 16, 2019Apprentice
Network map keeps randomly changing on iPhone app
When I look at the Network Map in the iPhone app, I keep getting always different network topology and differen colours for the devices (green, magenta, orange) every time I look at it!
Strangely e...
Daniel-UK
This could be a reasonable explanation looking at the pictures and I also splitted 2.4 and 5 Ghz ssid
However
1) from the Web interface 10.0.0.1 the back haul connection is good. Only rarely I saw config sync
2) the daisy chain setting is disabled. There should be no daisy chain topology
3) the Internet speed is very good. However there seem to be handover problems when moving around
I tried all the suggestions from agents and found on the Internet (reduce power, enable/disable fast roaming,mimo, etc) but no luck to have a stable network with a stable topology
However
SW_
May 16, 2019Prodigy
However
There's no setting that could save Orbi from this situation that I could find, except for mering it back to single SSID. MrMediaGuy had resisted and finally submitted. Check this thread for the issues with splitting SSIDs and how it was finally resolved. I was also skeptical when I first proposed the solution.
- Daniel-UKMay 17, 2019Apprentice
Thanks you so much SW_
Reverting back to SINGLE SSID fixed all my problems.. except that iPhones often are connecting to the 2.4Ghz and getting only 50Mb/s instead of 100Mb/s...
I bought Orbi because reviews advertised the dual SSID.. now it looks like it is either accepting sometime a lower speed or return it back to Amazon..
PS. this community is Amazing.. but Netgear support is abolutely the very worst ever!
- SW_May 17, 2019Prodigy
Daniel-UK, to improve 2.4Ghz speed, please disable 2.4Ghz co-existence (untick the box). If that doesn't help, try reducing the transmit power for 2.4Ghz from 100% to 50% or even 25% to nudge the iPhone toward 5Ghz. After you made the change, reboot Orbi and give it ~15mins for the dust to settle.
I have already done exactly what you suggested. Unfortunately with no luck, even with 25% power the 2.4Ghz is preferred :-(
Now I have a perfectly working network but speed is limited because the band steering doesn't seem to work properly :-(
I read quite a few threads on this issue and also BEAMFORMING not helping/working..
As an alternative, is there a way to make the splitted SSIDs working? Should I try to get back to an old firmware?
