OfficerUA
Apr 03, 2026Aspirant
Network map
I have a bit similar problem. I have a router with the latest firmware version (V7.2.8.2_5) and a satellite with an old version (V3.2.17). The satellite appears online as a "router" and does not all...
OfficerUA
RBR750 Router (V7.2.8.2_5) + RBS 750 (V7.2.8.2_5) Satellite communicate and work perfectly. Satellite RBS 750 (V3.2.17) failed to upgrade online, then I tried to download the firmware via nmrpflash. Only versions V3 were suitable for downloading (not exceed limit 32 MB). All newer versions V4, V7 exceed limit 32 MB and can be used with working web server only. Unfortunately ORBI Router (V7.2.8.2_5) does not allow to use outdated security certificates for V3 version, so RBS 750 (V3.2.17) is visible but cannot be used in Mesh system. My question is how to make RBS 750 (V3.2.17) usable again.
Apr 03, 2026Guru - Experienced User
Give 3.2.18.1 a try, then see if first version of v4 FW will load.
Have you performed a 30-30-30 reset on the RBS?
