OfficerUA
Apr 03, 2026Aspirant
Network map
I have a bit similar problem. I have a router with the latest firmware version (V7.2.8.2_5) and a satellite with an old version (V3.2.17). The satellite appears online as a "router" and does not all...
OfficerUA
Performed a 30-30-30 reset on the RBS - no result.
FW versions 3.2.18.1 and v4.x exceed 32 MB limit and cannot be loaded.
It is necessary to make the satellite "visible" in http mode.
- FURRYe38Apr 03, 2026Guru - Experienced User
Is this the original RBS that came with your RBR or did you get his one RBS 2nd hand?
Seems like this one RBS is in some bad state and can't be cleared out or resolved.
To get at the self service web page of the RBS, just need to factory reset it and don't sync it to anything, then you can access it's self service web page and update FW there with a ethernet PC as discribed in that guide. However if it's failing here, seems like this RBS needs to be replaced.
