KenLind
Nov 22, 2018Aspirant
Newtork map in ORBI app does not show devices when selected
ORBI Rounter RBK30 AC3000 FW 2.2.1.210 Using ORBI APP ios 2.2.8.14
Devices disappeared from network map when selecting satellite.
RBR50, 2xRBS50. From network map, you used to selecet a satellit...
- Nov 23, 2018
Devices are showing in a list format on my app after selecting the base router or satellite.
ekhalil
Nov 22, 2018Master
True, I also see the same behavior.
When this happen I just go to the main Network Map (that shows the tree of router and satellites) and pull the page down to refresh the status. After that when I select the router or satellite I will see all devices correctly displayed.
