KenLind
Nov 22, 2018Aspirant
Newtork map in ORBI app does not show devices when selected
ORBI Rounter RBK30 AC3000 FW 2.2.1.210 Using ORBI APP ios 2.2.8.14
Devices disappeared from network map when selecting satellite.
RBR50, 2xRBS50. From network map, you used to selecet a satellit...
- Nov 23, 2018
Devices are showing in a list format on my app after selecting the base router or satellite.
Shinedown
Dec 20, 2018Apprentice
I have the same issue - I've not been able to see what devices are connected to the router or satellite since installing my RBK50 in June... Orbi in AP mode, orbi app for Android, Android Oreo on Galaxy S9. Would really appreciate a fix for this if anyone can help...
Dec 20, 2018Guru - Experienced User
What FW version are you using?
Does this not work for you?
"When this happen I just go to the main Network Map (that shows the tree of router and satellites) and pull the page down to refresh the status. After that when I select the router or satellite I will see all devices correctly displayed."
